TractorLinks.com
Show Parts for Model:
Re: Air cleaner blowing oil
Jason S.
09-13-2013 06:39:00
If you have a leaking intake valve it can let the compression blow back into the intake which would blow the oil out, but while the tractor is running all of the oil is sucked up into the wire mesh in the air cleaner. After it sets for a while all the oil drains back into the cup. Check the oil level after it has set overnight or for several hours first if it doesn't reappear the remove the cup and crank the tractor and hold your hand up to the breather and see if you feel compression blowing back because there should only be suction there.
