TractorLinks.com
Show Parts for Model:
Re: Hydraulic pump check valve?
Jerry/MT
09-12-2013 16:51:36
Sounds like your control valve is stuck in the foward position. If the lift arms are up, make sure the engine is off and remove the side plate and pull the contol valve toward the rear. The valve body should move back about an inch and the lift arms should drop. Make sure the "T" shaped valve stem is hooked to the lower arms on the "H" shaped control fork. If they are then the valve may have some crud that"s causing it to stick.While you"re there make sure all the pieces of the control linkages are there and are attached properly.
