Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: valve setting
Jason S.
09-11-2013 06:29:37
The old way of setting valves was bring each cylinder to top dead center on the compression stroke and adjust the valves to .013" hot or .015" cold. Ferguson recomended setting the valves while it was running.I use the more modern method which is more accurate and assures that the lifter is on the backside of the cam when you set the lash. Do one cylinder at a time. Start with the first cylinder,turn the motor over until the exhaust valve starts to open and adjust the intake valve. Then turn the motor until the intake valve has opened fully and is almost closed and adjust the exhaust valve. Then proceed to the next cylinder.
