TractorLinks.com
Show Parts for Model:
Re: piston rings
Z-man
09-08-2013 17:32:24
I have not moved the timing at all yet so i'm thinking timing it while running. I believe it should be real close rite now but I would like to check it so I know it is rite on for max power when in use. also I was going to use a timing lite but is there an advance that needs to be dressed before I try to set the timing or do I just put the lite on number one and look through the timing window?
Jason S.
09-08-2013 17:50:15
 Re: piston rings in reply to Z-man, 09-08-2013 17:32:24
You have to have it idling at 400 rpms to set the timing. Anything above that and the advance in the distributor will be kicking in. Have it idling at 400 rpms and shine the timing light in the hole and set it to 6 degrees BTDC.
Z-man
09-08-2013 18:21:45
 Re: piston rings in reply to Jason S., 09-08-2013 17:50:15
ok sounds good what if it idles a wee slower than 400 rpms would that hurt, or does it have to be rite on 400?
Jason S.
09-08-2013 19:20:11
 Re: piston rings in reply to Z-man, 09-08-2013 18:21:45
A little slower will be ok because the advance won't start advancing the timing until you start going above 400 rpms.
