Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: piston rings
Jason S.
09-08-2013 07:46:40
I remember years ago I went to Briggs and Stratton school and they showed us a video of an engine that had a cut away at the cylinder and sure enough while running the rings do turn on the piston. Everybody has their way to install rings the main thing is to make sure none of the gaps line up or are even close to each other. Usually on a 3 ring car engine I install the oil ring with the gap over the piston wrist pin. Then I install the top and bottom expanders with their gap 180 degrees from each other. Then install the second ring with the gap to the bottom side of the piston and the top compression ring with the gap towards the top side of the piston. I"ll see if I can get you a pic.
Z-man
09-08-2013 15:23:41
 Re: piston rings in reply to Jason S., 09-08-2013 07:46:40
thanks, that's helpful though my piston only has a total of four rings but helpful. by the way do u know how to set the timing on a t0 30
Jason S.
09-08-2013 16:24:31
 Re: piston rings in reply to Z-man, 09-08-2013 15:23:41
Are you referring to setting the static timing or setting timing while it"s running?
Z-man
09-08-2013 17:32:24
 Re: piston rings in reply to Jason S., 09-08-2013 16:24:31
I have not moved the timing at all yet so i'm thinking timing it while running. I believe it should be real close rite now but I would like to check it so I know it is rite on for max power when in use. also I was going to use a timing lite but is there an advance that needs to be dressed before I try to set the timing or do I just put the lite on number one and look through the timing window?
Jason S.
09-08-2013 17:50:15
 Re: piston rings in reply to Z-man, 09-08-2013 17:32:24
You have to have it idling at 400 rpms to set the timing. Anything above that and the advance in the distributor will be kicking in. Have it idling at 400 rpms and shine the timing light in the hole and set it to 6 degrees BTDC.
Z-man
09-08-2013 18:21:45
 Re: piston rings in reply to Jason S., 09-08-2013 17:50:15
ok sounds good what if it idles a wee slower than 400 rpms would that hurt, or does it have to be rite on 400?
Jason S.
09-08-2013 19:20:11
 Re: piston rings in reply to Z-man, 09-08-2013 18:21:45
A little slower will be ok because the advance won't start advancing the timing until you start going above 400 rpms.
Jason S.
09-08-2013 08:07:02
On a 4 ring piston, and this is a Ferguson piston I'm holding I do the oil ring and expanders the same. In the pic the right hand side of the piston goes to the front. I install the oil ring gap over the right hand side of the wrist pin, and then the expanders 180 degrees from each other. The second ring I turn the gap to the back and then the compression ring and the third ring I install with the gaps 90 degrees from each other.
Copyright © 1997-2015 Yesterday's Tractor Co.
