The governor on my TO35 is very slow to engage when you lug it down. When throttling up it is quick to react and not go over RPM so it is doing something.
I backed the bumper screw off a little bit and found that it is probably backed out as much as it can be 'cause it fell out. What wears out that I might have to replace, or did someone just back it off too far in the past?
I have adjusted everything else as per John (UK)'s specs as best I could. Maybe have to go over things one more time just to make sure.
