TractorLinks.com
Show Parts for Model:
Re: Ideas?
Jason S.
09-03-2013 06:38:28
The delco generator should put out around 20 amps. All you should need for bush hogging is a sway bar. Look up marlowes method on here for how to hook up your bush hog, although I don't do it myself. I just set my lift in the neutral position and move the quadrant stop up against the control lever. Everyonce in a while I'll have to move the control lever to correct the lift but not that often. Doing it that way also depends on how good of shape your lift is in and if it has been adjusted properly. That's also how I move round bales of hay with my TO-20 but Marlowes method may work better for you.
