To 30 wiring diagram
KRK
I need a wiring diagram for my To 30 using a (2 wire) alternator. the Fena site shows a generator with a regulator. I would like to know if there is one available with the alternator. Tearing down to paint and want a backup diagram to back up my chicken scratches diagram I made.
Thanks Jason but I need the wiring to the ignition switch, ammeter ,coil, hour meter, lights,, etc. I also have a solenoid instead of the original used with the shifter. It looks like what I have could be simplified from the way it was wired by the previous owner.
Well the solenoid makes it more complicated than it needs to be but if you are going to keep the solenoid then just use a wiring diagram for a Ford 8N that has been converted to a Delco alternator. They use a solenoid on the starter.
