Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Alternator Question
08-23-2013 14:08:30
The ignition switch I have is a key switch bought from Tractor Supply for my tractor.
I have a three wire alternator with the sensing wire connected back to the battery post on the alternator.
I never said I didn't have spark. When I shut my tractor back off, the battery is completely dead and will not crank the engine over. As soon as I hook up the jumper cables, it fires right up.
I'm going to put a new alternator on tonight and see what happens.
08-23-2013 16:00:28
 Re: Alternator Question in reply to jcmorgan31, 08-23-2013 14:08:30
I misunderstood. I assumed you were doing all this with a charged battery. Are you sure your alternator hook-up isn't draining the battery? Obviously the alternator is charging or the machine would not run with a stone-dead battery. So the question in my mind is - why isn't the current that is suppling the ignition coil making its way to the battery to charge it?
Seems either your alternator output is not connected to the battery - or you've got a bad battery - or your alternator is draining it after shut-down.
How are you getting current to the #1 exciter on the alternator? You cannot wire it directly to the IGN terminal on the key-switch unless you stick in some resistance or a diode. You CAN run it to the ACC terminal which is isolated from the IGN when the key is off. I'm assume that part is working OK if the engine shuts off when you turn the key off.
