Points for Ferguson B-bottom plow
Anonymous-0
Looking for points for my Ferguson B-bottom plow:
Part numbers: 660046M91, 475142M1
numbers on original points: HF 12 BE-A0-131
numbers on a replacement point: HF FF WB
Thanks for any help.
I looked thru my books and I didn"t find the 475142M1 number for that plow. The only HF 12 BE AO number I found in the book was 130 instead of 131. What you are calling the point are you referring to the saddle?
475142M1 is a number I got from an online parts manual for an MF62 plow - I have a MF62 plow I use for parts and it is basically the same as my Ferguson. Points are interchangeable.
The ferguson A0 mouldboard plows parts book gives several alternative numbers for the B-type share/point: 660609M1, 660610M1,660046M91, 660608M91, and 660558M91. The saddle part number for that plow is 660485M1.
I have a #62 plow and I put new shins and shares on it about 6 months ago. Mine is a 2 14". I'll see if I can find the numbers where I wrote them down. I bought my shins at TSC and my local Massey dealer keeps the shares in stock.
If you have a #62 for parts you may want to swap it over to the replaceable shins and the regular type shares. The old Ferguson type shares are getting hard to find and when you do they are very expensive. There is a guy that comes on here some and he is on that n tractor site that goes by the name Scott PA. He has a lot of NOS plow parts. He would probably be your best bet to find the original type.
