P-AO-20 PLOW PARTS
You can still get them from Agco. 660126M1 is for the thicker 1/4" disc instead of the thinner 3/16", which is good because the 3/16" break a lot easier and wear down faster. The smooth 1/4" is about the only ones left that are available from Massey. They are $148.20 a piece.
You mean for one of these? What's the 21? Notched disc? The feller that sold this to me said it needed a castle nut. I looked inside the tube for spare parts, all I found was an empty Lone Star beer bottle and a bees nest...
Just bought the plow and the front disc is cracked but both are worn. I am located in MO. near Kansas City. If I could find used that would be great but good to know they are still available new.
Hey you finally got one Tony. I started to pick you up a Dearborn disc plow yesterday. I hauled some scrap metal off and there was one there. The tail wheel was missing but everything else was there including the weight. I could have got it for $50.00 or a little less.
It will be hard to find any good used discs for them. I have seen the discs welded and ground down before. The disk plow I have for my farmall had been done that way many years before I got it. $148.00 seems high for a disc but Case New Holland wants $264.00 for the same disc. Go figure, must be the greedy Fiat people...lol
wonder if you could use a large dia disc blade.
some of them are in the 22-26" range.
just lay the old blade over the new one, center it and with your torch, blow out the attachment holes.
have never priced one of those large disc blades, they may be just as high as the correct part, if you can find it.
I bought a new plow coulter blade 18" and used this method to blow out the holes for the replacement rear guide wheel on my fergy disc plow (MF 64 bent tube disc plow).
have read that ferguson included tools inside the tube, take end cap off, I have never tried to take a end cap off, anyone know if this is true?
