Need quick Electric circuit help
Jeff-oh
I went to load the tare-down tractor for the FENA expo this weekend and she won"t start.
I want to pin point this as I do not have time to shot gut this or that.
What I know:
TO-20 Cont. z120.
Fuel flow ok
Coil showed 2.2 ohms across the terminals that drifted down to 1.9 over 5 to 10 seconds.
No Spark from center lead of coil (disconnected from center of cap then placed next to ground.
I removed the cap and no spark across the points.
With points open I get 6V at the coil. 6 V at the distributor. (and near side of points.) nothing opposite side of points obviously.
When closed Voltage drops to .3V or so.
That"s what I know. Where to look next?
Jeff
Update. I did not have the key on before.
With the key on I get a weak white spark from the coil center wire to a ground point. I rechecked the ohms and it is 3.0 ohms
I checked my TE-20 which won't start either. And it has 4.4 ohms across the coil.
I am thinking it is the coils.
If not the coils then maybe a dodgy ignition switch? , corrosion or bad contacts only allowing a little current through .
Good spark now and the tractor is loaded. See you at the Expo.
Tractor building Friday, and Sat. Step up and say hi. I"ll hand you a wrench/spanner
