PTO Shaft Needle Bearing
? I've removed everything out, the pump, the pinion shaft, everything so I can get a clear shot at the bearing retainer. I've made a driver out of a 35mm socket and a 5/8 rod, I've beaten the daylights out of it, I've heated the cast around the retainer. NO MOVEMENT. Any idea's? I removed a 57 year old rusted front pivot pin that hadn't moved in 57 years. A little heat and a big hammer did the job fairly easy. But I cant get this clean looking retainer out that's been in oil for 57 years. Go figure!!!!!!!! ANY IDEA'S
