Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: To-20 timing
Trac
08-06-2013 10:20:09
with out tearing everything apart it can be done find compression stroke on #one piston thumb over plug hole if you can find your timing marks that will help alot slid dist. back in with points just about to open remember your timing order that should get you running again.
F-Bomb
08-06-2013 19:54:53
 Re: To-20 timing in reply to Trac, 08-06-2013 10:20:09
Done all this multiple times, finally found manual and set point gaps and set timing advanced as points just barely open using "30" on the flywheel timing numbers yet still not running, I do hear some firing so I'm getting closer, good fire and compression, deff. Have fuel for I can smell it, may be flooded. I'm going to let it sit and try it later. Thanks for the input
