up and running
bdunegan
just wanted to post that my to20 is back together again and everything works great. New clutch, pressure plate, release bearing, pilot bearing and new clutch fork. used old hub and seems to be working fine. went back together using guide bolts and nuts to squeeze it together, then used pipe wrench on pto shaft and it aligned right up. adjusted it to 3/8" from footpeg after taking out slack on shaft. works in all gears with no grinding at all and after warm up, has 20 lbs oil pressure at idle. thanks everyone for all the help and especially Jason S. for parts i needed. thanks everyone!
Hooked up a grader blade and done some dirt work. Everything worked great. Now I am just fixing small things to get it like I want it. Thanks for everything.
good to know. keep his contact info. i might need some parts later on. right now i need a leveling box for my lift arm, but wife tells me no more hobby money this month. LOL
box is still there, but shaft wont move either way when you crank handle. i can put pipe wrench on it and get it to move about one turn but that is it. didnt know these were re-buildable.
Yes they are rebuildable. There isn"t much to them actually. This site has the individual parts for rebuilding one.
