TractorLinks.com
Show Parts for Model:
Re: 12V coil on 6V tractor?
Trac
07-27-2013 06:48:02
I should have added on the 6 volt coil + side goes to the distributor if not you'll get premature failure on points. just a thought but your compression may be low but easier to start when warm?
rvirgil_KS
07-27-2013 11:45:02
 Re: 12V coil on 6V tractor? in reply to Trac, 07-27-2013 06:48:02
With positive ground + on coil goes to distributor, with negative ground - on coil goes to distributor.
Reversing should not affect points life but will reduce spark efficiency. Symptom I've seen with this several times with reversed coil wiring is harder starting when engine is cold. (Cold as in having set overnight, not necessarily winter time)
