TractorLinks.com
Show Parts for Model:
Re: To30 drops oil pressure
Brian Patterson
07-26-2013 15:46:46
Does the steering gearbox work from the same GL1-90
oil? What I mean is,does it pump oil up into the steering box,or does it require being drained separately and filled with a different lube?
I don't mean to sound like a big dummy!!
My grandfather passed away and left the tractor and
I never asked him that question.So,I figured I'd ask
you fellers.Thank's for being here on these forums!
Richard L
07-26-2013 17:39:48
 Re: To30 drops oil pressure in reply to Brian Patterson, 07-26-2013 15:46:46
The steering column has its own oil supply inside the steering housing and that plug you should see at the bottom part of the steering column is where you add oil or better yet corn head grease. You can find this at most tractor dealers. Corn head grease is a thicker oil so if your seals are a little bad it may not go past them as easily as the regular GL-1 oil.
2tractors
07-26-2013 17:23:49
No dumb questions on here just those with less seat time, The steering gear filler is under the battery box.
