TractorLinks.com
Show Parts for Model:
Re: Piston ring end gap
rustred
07-26-2013 08:34:58
the spec. is .003-.004 for every inch of cyl. bore. you are approx. double the tolerance. no you will not see smoke but it must be using some oil. the rings are worn and cyl's must have wear also. put the used ring in the bottom of bore and then measure the end gap. if it is less, then the cyl,s have wear "taper" also. do the same with the new rings also.
