Dale Lehman
New User
Was brush cutting the other day and after I finished while I was pulling out of the field I snubbed the tractor. When I tried to restart it would not turn over. After engaging the starter several times it turned over and started but then quit again as if I popped the clutch and snubbed it even though I did not. I checked the starter and it was fine then tried to start it again. Each time I engage the starter it will turn the crane a 1/4-1/2 inch. after several tries it seemed to go back to normal turned over and started but quit in a couple of seconds. It's almost like it is under extreme compression and can not turn over with the starter. Any ideas that might get me going in the right direction?
Dale
Dale
