Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Gas in the Oil
maxwell99
07-08-2013 07:29:37
only thing I might add, is do this twice
be sure to let all the oil drain out good, not a quicky, I am in a hurry oil change.
use a new filter each time
run the tractor until its at operating temp then drain the oil again.
that gas in the crankcase will start to clean the old crud off the insides of the engine and then it will/can stop up oil lines
then you could have real problems, scored bearings etc:
good luck and as said before, learn to turn off that gas shutoff valve each time, you just can not trust the old carb floats.
remember: old dogs can be taught new tricks, if it cost them enough!!!!!!!!
believe me I have had to drain the carb a few times when I forgot to cut gas off.
had to get up from my lazy boy and go back out to tractor shed and double check to insure I cut off fuel valve.
I need to put up a big sign in the back side of my tool shed, on the wall right in front of where I park the old tractor
CUT OFF FUEL VALVE
oldmisterbill
07-09-2013 13:13:43
 Re: Gas in the Oil in reply to maxwell99, 07-08-2013 07:29:37
The ole Marvel Scheblers had a habit of leaking with very little aggravation. Even when rebuilt they would love a tiny excuse to leak. I went to Grose jets it helped but any impurity in the fuel and there was trouble. With the old rusty tanks it is even worse - also tractors get fueled often from gas cans (a great invitation to get dirty fuel. Being human (at least part I hope) I also have left my fuel on , I put a note by the Ignition switch. But being absent minded and the sign was an "old thing" I got used to fast, I decided I needed help. I looked on ebay and bought 4 or 5, 12 volt electric fuel shut offs. I have on on each tractor -they automaticly shut off when the ign is turned off. I look and find them for less then $30.00 & I never shut the fuel off at the valve. My Fergy will get one this week.
maxwell99
07-09-2013 18:22:33
 Re: Gas in the Oil in reply to oldmisterbill, 07-09-2013 13:13:43
good idea on electric shutoffs.
I thought about adding one to mine.
but too lazy,
figured they would be like the gas cutoffs, in time they wear and will not cut the gas off to carb.
then its a drain tank and replace cutoff and they are like the carb kits of today, no longer the quality they used to be. one time I got the third one before I got one that would seal when cut off. may have been a bad batch, I try to buy the best one I can get.
like most things for our old tractors, made across the big waters.
oldmisterbill
07-09-2013 19:17:23
 Re: Gas in the Oil in reply to maxwell99, 07-09-2013 18:22:33
I keep the original sediment bowl & shut off valve. Then put the solenoid valve in line (some of them aren't much bigger than an inline filter. The first one I installed in 1994 on my Case 300 is still working fine. the good is that on a hot Oklahoma day if the float sticks shut off is instant -reducing a fire hazard. I will try to get a pic tomorrow if I can.
Copyright © 1997-2015 Yesterday's Tractor Co.
