Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 3 pt hitch hydraulics on 1955 TO-35
Tony C.
07-07-2013 03:32:06
Would you be replacing the oil because it's a good maintenance thing to do, or are you hoping it will fix the weak, pulsating hydraulics? In my experience unless someone installed the incoreect oil in the past (too light, like Ford 134, not GL-1) the fresh oil will not help performance much and you will have to rebuild the pump and lift cylinder to get it to work like it should. You could give it a try, although as someone else said you will need 8 gallons of GL-1. Even if it doesn't help the 3-point, at least you know you'll have fresh oil in the trans and differential if you can get by with using the hydraulics the way they are.
