TractorLinks.com
Show Parts for Model:
Re: TO-35 Governor issues again
Inno
07-05-2013 13:47:27
If everything looks ok then it might be worth re-adjusting as per John's instructions. Failing that it sounds like it could be internal which would be a much bigger job. I would think the adjustment screw on the opposite (distributor) side of the engine would be something I would try.
aarolar
07-05-2013 14:49:23
 Re: TO-35 Governor issues again in reply to Inno, 07-05-2013 13:47:27
Yes sir I checked that screw and it was still locked tightly where I set it originally but I may try adjusting it in some to see if that gets anywhere. I need to make it through this grass mowing season and I could tear it down this winter and check the internal components.
2tractors
07-07-2013 05:25:59
 Re: TO-35 Governor issues again in reply to aarolar, 07-05-2013 14:49:23
Somewhere in the manual it said that if the oil hole in the cam is clogged then the govenor won't work.
aarolar
07-07-2013 12:29:40
 Re: TO-35 Governor issues again in reply to 2tractors, 07-07-2013 05:25:59
Where is this located what cam?
2tractors
07-10-2013 15:14:20
 Re: TO-35 Governor issues again in reply to aarolar, 07-07-2013 12:29:40
Couldn't read my page #'s but it in group1 section B figure 43 and it said vent hole.
aarolar
07-10-2013 15:27:42
 Re: TO-35 Governor issues again in reply to 2tractors, 07-10-2013 15:14:20
Its in my manual as well there is a note in the R&R section on the governor.
2tractors
07-11-2013 05:27:59
 Re: TO-35 Governor issues again in reply to aarolar, 07-10-2013 15:27:42
The cam is inside the block behind the large gear and the govenor. Pulling the cam would be a bad idea as that will drop the lifters down into the block if I remember correctly although the vent hole is toward the front looking at the figure.
aarolar
07-11-2013 06:05:54
 Re: TO-35 Governor issues again in reply to 2tractors, 07-11-2013 05:27:59
We will know soon enough I will try and take some pictures to help clear things up this seems to be a common topic around here.
Tony in Mass.
07-11-2013 19:11:19
 Re: TO-35 Governor issues again in reply to aarolar, 07-11-2013 06:05:54
Ya know, a few months ago there were a few threads on governor springs, a hidden one infront of the manifold, usually just hanging there or gone altogether, the one wrapped arounf the throttle linkage, sometimes another acting as a carb idle/ gov return just for good measure. If you go into the achives here and the MF forum? There should be several hits and tons of pictures. If it is a spring, atleast you won't have tear the front clip apart...
