Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: TO-35 solenoid grounding
06-27-2013 17:01:34
The three post configuration is what would be considered the original setup, and should be all you need. The 4 post that is on there is likely from an automotive application: That 4th post takes the 12v+ from the large battery cable and sends it to your ignition coil, to alleviate the problem of low voltage through the ignition switch while hitting the starter. On the 35"s it isn"t really an issue- especially with 12V, since they crank over so easily (therefore not dropping the voltage enough to affect the ign. coil), so the 3 post solenoid you purchased will work like new for you. All you need to do is determine which wire comes from your starter button, and put that wire on the little post of your solenoid. The wire that was originally on that 4th post will not be needed anymore- you can just tape it off or remove it- it should lead to the + side of your ignition coil. One of the two big posts goes directly to the starter, the other directly to the + battery side.
Best of luck and congrats on your "new" Fergie
P.S. If you ever decide to paint this tractor, the original colors should have been dark green on the cast iron, and light gray sheet metal I believe, if you like keeping stuff original.
06-27-2013 20:01:58
 Re: TO-35 solenoid grounding in reply to Gearhead210, 06-27-2013 17:01:34
Thanks so much for the detailed explanation. I appreciate it.
I also know this guy has been re-worked to what appears to be a slightly newer (late 1950s?) color scheme. I haven't found much of the original paint, but then again, I haven't tinkered that much.
Looking forward to plenty more learning--
