TO20 Crankshaft Pulley
SB in IN
I hope someone can help me. I have a TO20 with a worn out crankshaft pulley. I have read several posts about a one piece crank pulley used with a hydraulic coupler for live hydraulics. My tractor is not equipped with live hydraulics. It has a stamped steel pulley with six indexed bolts to time the pulley. I have had no luck finding a pulley. Does anyone know if it is available and where I can find one? Will I have to buy the over priced one piece pulley even though I don"t need it. I would appreciate any info you guys may have. Thanks, Scott.
That isn't the stock pulley you have on there. They originally had a cast one piece pulley that is held on by a big bolt where you engage the hand crank if needed. The coupler you are talking about is if you want to add an external hydraulic pump to the front of the tractor to run a loader or something.
I kind of figured I was gonna have some odd ball piece of junk that no one has ever seen. I guess I will just buy a new one piece pulley and be done with it. Thanks though.
