TractorLinks.com
Show Parts for Model:
Re: Starting TO-20 hot.
oldmisterbill
06-26-2013 07:30:09
Is it shutting down on its own when hot? I don't see you mention that. So assuming your shutting it down and it doesn't restart well. Especially if your running 6 volts. A 6 volt system requires more amperage (about twice as much" to do the same job as 12 volts. So heat can become a problem resulting in starter drag. Does it turn over sluggishly when hot starting? Check your ignition well if its all ok make sure it isn't flooding with a rich mixture. Then check the starter & battery. Many 6 volt baterys have fooled a person into other repairs,and many 6volt starters have caused many people to change ok batteries. I say ok batteries because I was never a fan of 6 volt (even though I grew up with those systems).In my opinion there were very few "good" 6 volt batteries. In other words 6 volt system has to have a good battery and a good starter for hot starting.
Arcticman
06-26-2013 07:54:22
 Re: Starting TO-20 hot. in reply to oldmisterbill, 06-26-2013 07:30:09
Yes I am shutting it down and it is very sluggish. I put a brand new battery in when I got the tractor. Eventually I would like to convert to 12 volt. No time right now.
Jason S.
06-26-2013 12:31:01
 Re: Starting TO-20 hot. in reply to Arcticman, 06-26-2013 07:54:22
What size are the battery cables? A 6 volt needs 1 gauge or 0 gauge to be able to draw enough current to crank properly. You also need to move the point where the ground cable grounds to the tractor. Originally it was on the dash but as they age and bolts become rusty that is no longer a good ground. Move the ground down on the bell housing or the back of the steering box and see if that doesn"t help. I converted my tractor back to 6 volt and if everything is in proper order....you will have no problems cranking it hot on 6 volts.
