late model clutch assembly
bluefarmman
New User
WILL THE LATER MODEL T0-35 FLYWHEEL ATTACH TO A EARLY MODEL TO-35 ENGINE. i HAVE A COMPLETE CLUTCH ASSEMBLY PLUS RESURFACED LATE MODEL FLYWHEEL THAT i WANT TO PUT ON AN EARLY MODEL TO-35 IF IT WILL WORK.
tHANKS
Yes. As far as I know, the Z120,Z129,Z134 and Z145 Continentals used the same bolt pattern on the flywheels.
Like Jason said, they will both fit the crankshaft... but the rest of the clutch parts may or may not, depending on ages and models, but since you have the whole set that came with the flywheel? you are fine.
