What model FergusonTractor do I have?
I have a Ferguson tractor found serial number 82771 behind steering wheel on data plate. Data plate has what looks to be Coventry, England. On engine block there is Z120-600.
I also took apart carburetor found it to be a TSX361. Found lots of rust in fuel bowl. What is best way to clean carburetor. Will probably be ordering carburetor rebuild kit.
That appears to be a TE20 with the Continental engine. If you look at my first picture the steering box and gearbox cover is all one casting on British and French built Fergusons.Second picture shows an American built TO20 Ferguson
Sam
Thanks for response
My tractor looks like the second picture. I was looking at my distributer cap and it has 'England' in raised letters on top of cap. I was looking at the starter and other electrical components to see if Lucas parts were used.
My data plate has England and what looks like Coventry.
It should be stamped TE,or TO then the serial # Do you know what motor is in it? if it's stamped Z120 on the block it could be ether one but if it's the Standard Motor Co. that would make it a TEA. but with Lucas elec. parts that should be a TE20.
UK built 1949 Ferguson TE20 with Continental Z120 engine. Amongst the last of the Continental engine Fergusons built in the UK.
Bob in Oz
