TractorLinks.com
Show Parts for Model:
Re: Gasket Sealer - Yes or No, and What Kind?
Jason S.
06-21-2013 15:22:00
I use copper coat for the head gaskets. The manifold gasket kind of depends, If you see any pitting on the head or the manifold flange then yes I would use some. Just a thin smear and I mean thin smear of either high temp red or copper. I always glue the valve cover gasket to the valve cover so when you remove the valve cover to adjust the valves the gasket stays with the cover which I usually use weatherstrip adhesive for that but you could use silicone instead. The rest of the gaskets shouldn"t need anything but sometimes I use Indian head shellac to hold water pump gaskets and oil pan gaskets in place. I apply it on one side only.
