Tom Bowman
Starting to put things back together on the TO-20, and wanted to know about what gasket sealer, if any, to use for:
1. Head Gasket (It looks like "Copper-Coat" is preferred for head gaskets, even though the 1950 Shop Manual says to use grease. I have a Fel-Pro head gasket.)
2. Manifold Gasket (Fel-Pro.)
3. Valve Cover Gasket (Again, Fel-Pro.)
4. Oil Pan Gasket (Don"t have that gasket yet. O"Reilly"s priced a Fel-Pro at $19.99, but aftermarkets are 5-6 bucks - is it worth the difference?)
5. Carb-to-Manifold Gasket (GB in MT rebuilt this carb, and he says to use nothing - I"m purdy dang sure he"s right!)
6. Water Pump Outlet-to-Cylinder Head (Thin paper gasket.)
7. PTO Shaft Cover Gasket (REALLY thin paper gasket.)
Thanks.
Thanks.
