TO-20 parts
The top of the blue column on the left, just keep choosing and clicking till you get to TO20 driveline.. another 3 day job for a 3 dollar part... be patient getting the brake drums off. I curse who ever decided to put flathead countersunk screws in there... good luck.
No problem getting parts here, I just started looking. Is the sure seal a good thing? We will probably work on it later this summer. Thanks Mike
Sure Seals work just fine. Short fiber wheel bearing grease. As used in Drum Brakes.
Proper axle end play is with the tractor jacked up, spin one wheel forward, the other will spin the other way. If the seal is not beveled on the leading edge, a file will put a nice chamfer on it for easier installation. 3' section of 3" ABS pipe can also make a nice installation tool.
That is most the info you might need.
