49-AC
New User
I found a harry ferguson tea20 .I need help on tractor ser# is 190988 i believe it is a 1951 model. the tractor has i-beam radias arms,step up and down transmisson,foot gas trottle & a aluminun transmission housing.tractors seems to have factory paint wich is green with grey fenders and hood. Tractor is in good condition and I need some advice on tractor and value. thanks
it shouldn't have I beam radius arms 9N or 2N had them must have reversed the axle extension or changed out with a ford axle? It should all be grey as far as price it's hard to say can you post pic. i have the aluminum hood (had to have it)i paid 2000 for mine.
PICS OF THE TRACTOR
Looks pretty much okay, but they could be right about the Ford front axle. On the Ferguson, the outer extensions are mounted on the front of the pivoting center section. Ferguson TEA 20s had a longer engine, so to fit the shorter Ford radius arm, the axle extension had to be mounted behind. Nice that it works out that way. The drag links may have been shorted some also, unless they are also Ford.
Foot gas throttle on a TEA20?????
And what is that second lever in the photo - a hand operated Clutch?????
Not Ferguson TEA20 radius rods.
Bob I think it must be either a Sherman or Hupp over/under transmission.
I expect it would be quite rare for a Ferguson.
I just looked up another site and it must be a Hupp over/under or both as Sherman transmissions appear to have the gear lever on the left side and Hupp's on the right.
Brad
