I have yet to look in the book. But tonight I removed the gas tank to retighten the new manifold nuts. I noticed to my dismay that a bracket which holds the front side of gas tank and what I guess is the end of the governor rod is broken in the middle right up against where the upper radiator hose connects. Whoever had it before me merely put a bar of steel across the gas tank flange an bolted through it like a large washer. Any ideas how to fix this mess? It appears to be cast metal. My first thought is to clean it up real well do some filing the JB weld the broken spot and reinforce on top of the bracket with 1/4" steel bar jb welded to original bracket with predrilled holes for gas tank bolts. Would this part even be available anywhere?
