Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Front gas tank bracket/throttle/ governor broken
Jason S.
06-04-2013 19:57:58
Those are plentiful used but if you wanted to fix yours I don"t know if JB weld would hold it or not, but it could be brazed back together and would hold better than JB weld.
kb3erv
06-05-2013 10:17:22
 Re: Front gas tank bracket/throttle/ governor broken in reply to Jason S., 06-04-2013 19:57:58
When looking at it I can't for the life of me figure out why it is even broken or even how. The bracket doesn't seem to carry much weight and it is evenly distributed across the whole bracket and the rod in the end hole does nothing but rotate. I will look at it better tonight if I have time and then decide but I think if I reinforce it with a 1/4" steel bar JB welded from one side to the other as well as JB weld the actual crack it should hold. It will definitely be better than jus one gas tank mounting bolt holding it in position.
