Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TO20 or TO30
Daniel Collngs
06-02-2013 22:15:45
I read about the sure seals being used on the TO20. Am I understanding you correctly that they can be used on the outter seal of the TO30 also?
Do I need to remove the old outer seal to use the sure seals regardless?
Oh my air intake is not on the dash. It is part of the air cleaner. That is another point that makes me believe I have a TO20 and I got lucky and got the late model motor.
Jason S.
06-03-2013 11:36:10
 Re: TO20 or TO30 in reply to Daniel Collngs, 06-02-2013 22:15:45
No...you do not have to remove the outer seals to install and use sure seals.
Richard L
06-03-2013 05:23:50
Count the bolts on the axle to center housing. The TO 20 and early TO 30 used 20 and you can use sure seals on these. The later TO 30 used 28 bolts and two seals so you should not use the sure seals on these. This is compliments of John (UK) in the archives.
Jason S.
06-03-2013 06:30:28
 Re: TO20 or TO30 in reply to Richard L, 06-03-2013 05:23:50
I learned something today Richard. I didn't know any of the TO-30's used the 28 bolt housings I thought that started with the 35's. If anyone would know John(uk) would know though....he has probably seen more Fergusons that most of us put together.The 30 we had was a 1953 and it had the 20 bolt housings.
