TractorLinks.com
Show Parts for Model:
Re: Ignition Switch Plate
Tom in MO
05-31-2013 07:59:34
Del, according to the Parts Book, that"s a "Plate, Ignition Switch Index", Part No. 181389M1. (We didn"t get one on a TO-20!)
If you do a Google search for that part number, you"ll get results for Ritchie Implement in Wisconsin; however, it says that part is a "decal", so I"m not sure what"s up. (608)623-2331 or (800)726-7278.
I was just recently in contact with Ritchie Implement, to get an OEM pivot pin/bushing for the TO-20, and they had a good price on those items.
Good luck.
Del Huebner
05-31-2013 12:00:20
 Re: Ignition Switch Plate in reply to Tom in MO, 05-31-2013 07:59:34
Thanks for the info Tom. I called Ritchie and it is in fact a decal that they have. Figured it wouldn't do much good without the plate to put it on. They didn't have it in stock anyway but said they could order it if I needed one.
Richard L
06-01-2013 12:42:44
 Re: Ignition Switch Plate in reply to Del Huebner, 05-31-2013 12:00:20
Del, if you got the decal from them you could take a thin piece of aluminum and trace around the decal on the plate and trim it all out and then mount it on the switch. Originally there was no decal it was inked onto the piece of aluminum. The actual thickness is .015.
Del Huebner
06-01-2013 17:26:13
 Re: Ignition Switch Plate in reply to Richard L, 06-01-2013 12:42:44
Thanks Richard, I think this may be the route to go. I have some .015 aluminum stock and the parts guy at Ritchie Implement said the decals were only $1.70 each so I will probably try this method.
