Marvel Schebler TSX458 Choke Shaft and Fly Assembly
JasonKS
I am trying to rebuild my TO-30 carb (TSX458). The choke shaft is bent, and the fly assembly (plate with screws) could also be replaced. I don't find these parts in any of the carb kits here (I ordered the comprehensive one anyway), and I don't see the parts separately. Does anyone know where I might get these? Thanks.
JasonKS
You can go to an Agco dealer and he can get them for from Parts Depot. I just looked and the throttle shaft is part number 1751207M91 and the throttle plate is 15490A. They show both of those to be in stock. The throttle arm might also work off of another Marvel Schebler for a Ferguson like a TSX 361A, TSX 312 and etc....
When I go to the parts depot, I don"t see a way to search on the part name. It seems to require the part number. What link did you use to search the parts depot? Thanks.
Go to the N Forum and holler for GBinMT. He ebuild M-S carbs and he might be able to help you with locating parts
Sorry about that I misread it. The choke shaft is no longer available new but it did show that the choke disc is still available. You can go to agcopartsbook.com and look up most any part for a Ferguson or Massey Ferguson and the go to depot parts and look for the availability. The choke disc is the same as a Ford N series but the arm is not. Ford used a ball on their choke shaft where Ferguson did not, but that isn't to say that you couldn't grind the ball off of the choke arm and hook your choke rod in to the hole. If you can find the arm off of the later Marvel Schebler TSXU series, they will work also. They were a universal replacement carb and the choke arm on the shaft was adjustable and had multiple holes drilled in it to work with most choke hook ups. If you don't have any luck I have a few spare parts laying around for the Ferguson carbs.
