Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Marvel Schebler TSX458 Choke Shaft and Fly Assembly
JasonKS
05-29-2013 07:52:16
I'll check out Agco, but I don't need the throttle shaft/plate. I need the choke shaft/plate.
Jason S.
05-29-2013 09:01:22
 Re: Marvel Schebler TSX458 Choke Shaft and Fly Assembly in reply to JasonKS, 05-29-2013 07:52:16
Sorry about that I misread it. The choke shaft is no longer available new but it did show that the choke disc is still available. You can go to agcopartsbook.com and look up most any part for a Ferguson or Massey Ferguson and the go to depot parts and look for the availability. The choke disc is the same as a Ford N series but the arm is not. Ford used a ball on their choke shaft where Ferguson did not, but that isn't to say that you couldn't grind the ball off of the choke arm and hook your choke rod in to the hole. If you can find the arm off of the later Marvel Schebler TSXU series, they will work also. They were a universal replacement carb and the choke arm on the shaft was adjustable and had multiple holes drilled in it to work with most choke hook ups. If you don't have any luck I have a few spare parts laying around for the Ferguson carbs.
Copyright © 1997-2015 Yesterday's Tractor Co.
