TractorLinks.com
Show Parts for Model:
Re: Power steering pump replacement.
Iowa Carl
05-14-2013 05:26:48
If you are considering a replacement combination pump, I would suggest using the Massey combine pump used in the 410 thru 860 series. The pump internals are adaptable to either ckock wise or counter clock wise applications.The flow divider is built in and the remaining flow is perfect for the loader. If you intend to always use the tractor with the loader, front mount the pump with the crank extension drive. If I were to do this application again, I would buy or copy the machine shop fabrication placing the pump behind the radiator instead of the traditional drive. An additional flow divider would give you full time live lift, full time auxillary hydraulic function, and full time POWER steering.
