TractorLinks.com
Show Parts for Model:
Re: To20 gas tank
johnpop1
05-13-2013 09:54:09
Having spent many thousands of hours on a to30, running out of fuel was never a problem. There is a 1 gallon reserve to be had by opening the fuel tank petcock full open. As I recall, the fuel valve tells you to open only 2 full turns for normal operation. I could be wrong, but this is my memory from 40 years ago. That Ferguson was the most reliable tractor on the farm. It would start without fail on the coldest of upstate NY winters.
Kurt Ridley
05-13-2013 10:12:33
 Re: To20 gas tank in reply to johnpop1, 05-13-2013 09:54:09
Thanks for the replies, i just got this tractor and it was running real good i ran it out of gas and it didnt even act like it was getting low just shut down after refilling it suck rust in lines made float stick . Took tank off and seen baffles broke loose inside . Washed tank ,cleaned float and it still sucking stuff through . Im going to buy a new tank and i was going to see if they was one out there that had a hole for a sending unit that would fit . That way never run it out again .
