Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Not a good day....argh
wforpm
05-11-2013 05:18:48
Quoting Removed, click Modern View to see :wink: OK , I JUST had to go thru this with my TO-30. I had the same problamo. I had turned the screw at the govener all the way out as to be finger loose. THEN , turned the screw in , FINGER TIGHT , untill it required a screw driver. Then kept turning in the screw 1 turn at a time , each time testing the engine with load , 4th gear w, brake on. Finally it started . The BALLS she was a moov'n. I then had to go back to the linkage to adjust the vertical rod with sping wrapped around it to get it to pull the throttle before the engine was going to stall. Be patient , keep cool , best if done with 2 people. So they can see if moving under load. My 2 cents........... :roll:
Copyright © 1997-2015 Yesterday's Tractor Co.
