Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Not a good day....argh
68massey204
05-10-2013 17:09:10
Nobody's got anything for me??????? come on guys :wink:
Kevin
IrvIa
05-12-2013 19:29:09
 Re: Not a good day....argh in reply to 68massey204, 05-10-2013 17:09:10
I know I'm a little late on this thread, but is that washer under the cam nut bent up to lock the nut? Those rascals have a habit of coming loose and causing all kinds of trouble. Irv
68massey204
05-27-2013 19:40:48
 Re: Not a good day....argh in reply to IrvIa, 05-12-2013 19:29:09
Well guys, I finally got this back together today and it works!!!! Thanks to all the help from everyone here and John(UK). I had the governor cup installed wrong and the nut was too thick not allowing the cup to seat fully, must have been replaced in an earlier rebuild, I didn't change it and never heard this thing run. I just ground the nut until it was flush with the cam.
Kevin
This post was edited by 68massey204 at 12:03:10 05/28/13.
Jason S.
05-10-2013 18:06:30
The governor parts look ok. You said the bearing in the governor housing was good. I can"t see the end of the bumper screw. Is it there? How far was it turned in?
68massey204
05-10-2013 20:40:05
 Re: Not a good day....argh in reply to Jason S., 05-10-2013 18:06:30
The governor was not working at all after the rebuild. After following John(UK)'s adjustment instructions I decided we needed to take her back apart. What I found was the governor cup "tab" was at twelve o clock as opposed to eight. I was wondering if this would cause it not to work at all. The first pic shows the setup as it was when I took it apart. The bumper screw doesn't show because I had it backed out all the way as per John's instruction.
Thanks
Kevin
