TractorLinks.com
Show Parts for Model:
Re: Pulled TO-20 Head...(Pictures)
Tony in Mass.
05-05-2013 19:07:28
Seen worse! Nothing here an angle grinder and scotchbright pads can't cure. Yeah, it just wasn't running right for a while. 2 head gaskets? Bet one is factory. I hope the previous owner wasn't trying to cure something, but I know some jeep and military vehicle guys double gaskets to get more power.. personally, I wouldn't do it. While you are this far, atleast take the valves out and sotchbright those too. Or... how far are you going to take this project?
Tom in MO
05-06-2013 05:19:54
 Re: Pulled TO-20 Head...(Pictures) in reply to Tony in Mass., 05-05-2013 19:07:28
Thanks, all.
Tony, this was about as far as I had planned to take this project. (Actually, not quite this far, but you know how that goes.)
I"m not sure I"m up to taking the valves out - I may still take the head in to the shop.
Can I use some kind of solvent on the carbon deposits on the pistons and head?
Jerry, I had some carb issues, so I"m hoping this is the result of a rich fuel-air mix, rather than an oil control problem.
I"ll be putting on GB"s new carb when I put "er back together!
Ark68SS
05-05-2013 20:51:44
DON'T USE SCOTCHBRITE PADS!! The abrasive in the pads can go down between the piston and cylinder wall and score the cylinders and/or the ring lands. The carbon is normal, if you want to get rid of it, bring the piston up to the top and use a scraper or razor blade to get it off. Wipe with a shop rag as you scrape it.
BillL
