TractorLinks.com
Show Parts for Model:
Re: TO-35 EXhaust manifold cherry red after 30 minutes
Jerry/MT
05-04-2013 14:01:40
Look for retarded timing and/or a lean mixture caused by leaks around the carb metering system. The usual culprits are cracks or rust holes in the intake manifold, leaks at the manifold to head gasket interface or the carb to intake manifold interface or around the carb throttle shaft. It"s also possible the main jet is set too lean. It should not be adjusted less than one full turn from full closed.
JMOR
05-05-2013 09:16:15
 Re: TO-35 EXhaust manifold cherry red after 30 minutes in reply to Jerry/MT, 05-04-2013 14:01:40
Quoting Removed, click Modern View to see.......and with regard to timing, don't just look at static timing. If the centrifugal advance mechanism is stuck or inoperable it can cause excessive heating.
