Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Not a good day....argh
matt p
04-28-2013 20:15:21
Do you have foot throttle peddle,if so make sure that it moves freely and the spring keeps the peddle at the top of its position,check for binding at the end where your cork washer would go also check hand throttle linkage clean and lubricate it all even under the dash!!!
68massey204
04-29-2013 09:13:03
 Re: Not a good day....argh in reply to matt p, 04-28-2013 20:15:21
I do have foot throttle and i am having problems with it but I wouldn't think it would matter.... Isn't the governor just working against the governor spring pressure? It shouldn't be trying to move the throttle pedal against the cork washer or the return spring correct? How much range of motion should the upright arm at back of gen. have when everything is working correctly? Mine seems to have no perceivable movement under load etc. The only time it moves is when I move the throttle.
Sorry guys, I am an auto technician but cars don't even have carbs anymore nevermind governors LOL
Thanks
Kevin
matt p
04-29-2013 12:02:41
 Re: Not a good day....argh in reply to 68massey204, 04-29-2013 09:13:03
On my 202 I have foot throttle, the spring in the foot throttle works as the compensating spring,mine was almost siezed up and the spring broken.I had to take the peddle off to get it to work properly. Push on the peddle and watch the action of you throttle rod (where it connects under the dash see whats its doing. My governer lever only moves a 1/4 to 1/2" from idle to full throttle.
Copyright © 1997-2015 Yesterday's Tractor Co.
