Del Huebner
On my front axle support where it bolts to the block there is a difference in the gap on the bracket that the bolts go through. The one has a gap of 11/16 inch and the other has a gap of 7/16 inch. The one that has the 7/16 gap had a spacer of 3/16 inch between the support and the block.
You can see the difference in the picture. Has this support been modified and should the space in the brackets be the same? You can also see the spacer in the photo, doesn't seem right but can not find much info on it. Thanks.
