TO-20 Manifold and Gasket...
Hmm...I think I'll replace this manifold gasket:
And, can the the mating surface of this manifold be machined? I think it's original (it has a "Z120" cast into it), so I'd to try to keep it, if possible. (There aren't any cracks that I can see.)
Thanks, Jason.
The head is going to the machine shop as soon as I get it removed, so I"ll send the manifold along with it.
Dumb question: do I need to remove the manifold studs before I take the head to the machine shop, or will they do it? (I assume they"ll mill down the surface on the head where the manifold mounts.)
They can remove them for you, and I would probably let them remove them because I would say they are going to be stubborn to remove since they have never been removed before. Is the head pitted up bad where the manifold mounts?
