Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Three point won't lift, did I screw up?
Jason S.
04-20-2013 05:29:07
I did the very same thing on my 175 once. The only difference is my 175 has pressure control which means there is a block in the middle of the standpipe. You can"t pull it out from the top and there is hardly enough room to get my big hand in the side cover and up to the standpipe to get it in the hole. If your lift arms are still hooked up, if the standpipe is in the hole in the bottom fluid can come shooting out if you move the lift arms even a little bit. I"ve had that happen also. While your at it, did you check the condition of the Teflon back up washers behind the orings?
257 Roberts
04-21-2013 17:45:20
 Re: Three point won't lift, did I screw up? in reply to Jason S., 04-20-2013 05:29:07
Yep, the pipe was the problem. Thanks alot guys!!
Number one cause of tractor problems: operator error
