257 Roberts
Hey guys. My 1955 TO-35 came with a single remote when I bought it back in 2007. I have nothing that uses remotes so recently I decided to install the block off plate. I took the single remote plate and hose off and put on the block off plate, I replaced the o-rings on the pipe and the holes on the bottom too. Now my three point lift does not work at all. I put the remote plate back on and same thing, it doesn't even begin to lift.
So, what did I do wrong here? I've always taken good care of the tractor, I replaced the tranny fluid with new GL1 90W last summer. It's filled up to the proper level. Could I have somehow introduced air into the system? I can try to post some pics if need be.
