Ferguson-TO gasket help
Hi can any one tell me what the big rubber round gasket that came in my gasket kit goes to? it not a main oil seal. And can someone also tell me what the 2 small wing shaped gaskets that are molded into the inside the oil pan gasket go to? on my 1953 TO-30 thanks
If your gasket kit fits TE20, TO20 and TO30 I think the big rubber gasket is for TO TE 20 oil filter. TO30 is different oil filter so you won't need that gasket. If gasket kit is TO30 only then I don't know the answer.
Those extra pieces of oil pan gasket are used for the Z134 engines on TO35s, MF50s etc. that have a cast iron pan that bolts to the bell housing. You don't need them for a TO30.
Dan
