TractorLinks.com
Show Parts for Model:
Re: Draw Bar
Tony in Mass.
04-12-2013 07:06:00
Humph. The stay bars the guys are showing you will prevent the bar you are using now from raising un-intentionally... which is needed when pulling a trailer for sure. But I believe you are using a like? - 2 inch ball? This still isn't safe when the ball to curl under that perforated bar. You will still have a trailer tongue in you back. It doesn't do the ball hitch any good either. The bar you are using is for adjusting the position of - trail-ing implements, most were horse drawn or other company's early trailing stuff. With a yoke and pin hitch, not a ball. The set that Dan posted is what you need- for safety and stability- like you must have found out what a monster backing up your trailer is with the bar you are using now? This kit, whether from this site, or a TSC near you, might be the only reasonably priced options near you? will lock straight when you need it to, or if you are in the woods or rough ground, you can let it 'swing', where it gets its name. Years ago when I was doing what you are now, with a 9n and a bar like yours, my father made sure the safety chains on the trailer tongue were wrapped and secured around the bar.... that's the least you should do till you buy a 'swinging drawbar set'. Be careful.
